1993 Smokercraft 182 Pro Mag
trudgers
Does anyone have a manual for this particular boat. I am trying to find the size of the fuel tank? Thanks for any help in this area.
Re: 1993 Smokercraft 182 Pro Mag
Ayuh,... Welcome Aboard,... Generally speakin',..
Boats don't have owners manuals, muchless anything with that kinda useful information...
Find the top of the tank, if you're Lucky, there'll be a tag with that Info...
Otherwise,... Measure, 'n calculate....
trudgers
Thanks for the Info I'll Try That however measuring will be tricky unless there is an easy way to do it.
P.S. Smokercraft came back with 47 gallons, I don't think so the boat would have to be mostly tank.
Again Thanks for the info
Low dsrt jon
Call the Smokercraft factory in Indiana. Ask for Andy Inebit, he has the answer to your question.:):):) LDJ. PS check the SmokerCraft Forums at the bottom of the page, just scroll down to you come to SmokerCraft. LDJ a proud SmokerCraft owner for ten years.
1fishbone
There should be deck access near the outlet of the tank.
That's where I found my capacity, molded into the tank...under the crud!
Mine was a tempo tank 36 gallons 16" W x 8-1/4" H x 68-3/4" L.
If there's no tag...measure and calculate!
