Fishjustin87
- Aug 7, 2018
- 113
I picked up a starter boat as a project to play with. It has a 94 115 Johnson on it. I have hood spark and all 4 cylinders are at about 125 to 130 with a wet test. I rebuilt the carbs and have had a problem with the VRO No oil sensor. Did the Vro oil test and its seems fine. I am losing vaccum in the tank. I am going to replace the oil pickup gasket to see if that fixes the no oil alarm. It fires and idles with a slight miss if I lift the throttle just a tiny bit but dies if I drop it all the way. Notices when I rechecked the compression that cylinder 2 and 4 had a little bit of water oil mix on the plug. Compression on 2 was 128 and 4 is 125. Could this just be a small leak in the head gasket? On a side not I get alot of oil in the water tank it's in after run ing for a little bit. Obvious thing to do is pull the head but is it more possibly the crank seal? I. Confused as to why compression appears to be good. It is an older motor that I would like to get one summer out of so I can upgrade to a bigger boat next year for the family and not be "That Guy" at the boat launch. Also if I manually fed the tube for the VRO test it did not sound the alarm. Let run 45 Minutes. New oil cap, pump the ball and oil comes out the line but can not blow back through to the tank from the main oil hook up point.
