1994 115 VRO Fuel Pump Replacement
Aprazur
The oil injection pump has been removed and the oil line off the fuel pump pluged for many years now. I am replacing the fuel pump, can I use one that isn't for the VRO system or do I have to buy the same replacement VRO fuel pump and plug the oil line?
boatguya1
Re: 1994 115 VRO Fuel Pump Replacement
I believe the pump from a 112spl will work there if your motor is a 90* v-4. If a 60* v-4 I don't know.
James
emdsapmgr
This current 3-port pump should work for you: 438559.
