Fishjustin87
- Aug 7, 2018
- 113
Has good compression and spark. Already dealt with a overheat alarm via thermostats and pump. 1st test run the other day and and seemed to be missing one cylinder. Idled rough but planned out great. After an hour of up and down in speed it sounded an alarm. Shut it down immediately and gave it a few. Tried to start and it only cranked. Next day cold started and ran really rough and then died. Would not start. Comp good
spark good. Pulled bowl plugs and pumped some fuel through and it fired great on all 4. Thought fuel restriction alarm. Put in water and started great. Let idle and ran up 3 min To help wife bring the kids down and was sounding no oil beeps. Shut down and checked each head temp. Only 95 F. Would not start. Tried flipping fuel solenoid and still nothing. Have not gotten to try again cold. Suspect carbs need rebuilt but why no oil alarm. Vro? Once alarm triggered can it shut down spark?. Plan to build carbs but am concerned about Vro. Side note. Tach does not work. Any help would be greatly appreciated
