Re: 1994 15hp mercury no spark
You'll have 2 wires coming from the stop switches. One pair from the switch in the end of the tiller handle and one pair from the cowl mounted switch. Each pair is one black, which is connected to the engine block, and one black with a yellow stripe, which go up to the power pack. Disconnect the black/yellow wires from the pack and see if you have spark.<br /><br />The shock it from the tiller handle stop switch and will only happen when the handle is wet.<br /><br />Chris........
