1994 Evinrude 50 HP Not Charging
Find a wiring diagram online.----mastertech marine.-----Early 1990's V-4.----Wiring is the same / nearly the same as your 50 HP.
Success! Thank you all. Interestingly, the RR allowed the voltage to run up as high as 15.4V before it settled down to a steady 14.4. (V confirmed by digital MM).
Thank you all, and hopefully those coming after me will benefit from this post, and not bother you as much as I did :)
saltchuckmatt
How many RPM's is your motor doing with the volt gauge where it's at in the picture?
dwco5051
If you are truly getting high voltage as measured with a known good meter check all your ground connections including at the battery terminal for loose or corrosion.
