1994 Seadoo XP only runs with start button engaged
dan2744
My Seadoo immediately dies when I let go of green start switch. It loses spark when switch is depressed.
alldodge
Appears to be a regular problem for doo's around your year. It can be a bad ground, the solenoid was replaced and the battery wire was connected on the wrong post, TPS cable or rev limiter. The essence appears to be a connection made incorrectly or corrosion. I just searched on seadoo dies when start button is released
https://www.seadooforum.com/showthr...en-stalls-as-you-let-go-of-the-starter-button
http://www.pwctoday.com/showthread.php?t=176558
http://www.pwctoday.com/showthread.php?t=326232
dan2744
It ended up being the main engine ground by the starter.
