1994 Trailmaster single axle 3500#
Patrick_L
Anyone out there who has worked on bearing replacement and knows size/codes ? I was hoping to buy parts ahead of time as opposed to taking it apart 1st and potentially letting it sit until parts arrive
Drcoffee
This was the Kit I bought for my trailmaster last year. I have the EZ lube axles.
Wheel bearing kit
airshot
Just remove the tire and hub on one side, get the numbers and put it back on until your parts arrive. Less than an hour easy work....then you know you have the right bearings!!
