Waternut2000
- Jun 21, 2009
- 4
My boat has twin 1994 Yamaha 225 TXRS engines. The right engine has an ongoing problem with no remedies that I can find.
On a cold engine, it starts fine and will run all day...until you shut it down. If you start the warm engine soon (within a few minutes, then all is well). If you wait perhaps 20 minutes or more..then engine idles like a plug is missing between 500-700 rpm. Putting it in gear usaully kills it when you throttle up. If you nurse it in neutral and ahigher RPM, it may clear up and then if you abruptly put it in gear and accelerate to mid mid or 3/4 throttle it clears up and will run fine again all day. I recently replace the Magneto Stator as advised by mechanic...no help.
I've spent a lot of money diagnosing the problem with no solutions.
HELP PLEASE !
Thank YOU for reading.
HELP PLEASE !
