Re: 1995 120 force outboard
Motor running right?Do a compression/spark test.
What RPM's are you running at WOT.That motor should run about 53-5500 rpm at wot.
An overloaded boat will hurt performance.
3 adults,2 kids,a dog,2 coolers and all the equipment and a full tank of gas.That might be too much.
Figure out the rpm question and post your results.Without that we can't really do much.
Some times a prop change can make a difference.
If your looking for a BIG jump in speed you need to do a big jump in horesepower.A 120hp, there isin't much you can do to make a lot more speed.Lighten your load,carry a half tank of fuel unless you use a lot.
Tell your friends to watch from tha shore
J
