1995 25hp. elect start bogs down at wot
wtrbuster
put new fuel pump on last year,so it should be ok, runs good for 100yds. then bogs down and seems to run on 1 cylinder, top spark plug is wet with gas, put 2 new coil-paks on same problem, can somebody steer me in the right direction?
boobie
Re: 1995 25hp. elect start bogs down at wot
Could be a bad power pack.
Run with a timing light and see if you lose spark on one cylinder.---Does the primer bulb go hard when you start the motor ?
