1995 4.3 Mercruiser
Terry Brown
I have a 1995 4.3 in a boat I have had for 8 years...It has 350 hrs on it....
I have winterized it the same way all of this time...( directions from Mercstuff.com). Anyway, I flushed it out 2 weeks ago, and it ran fine. I went to the lake, two weeks later and it was hydro-locked. Water in the back two cylinders on the right side sitting in the drivers seat...Some say a cracked block..I am doubting this as we have had far severer winters here, and I have alway's done the winterizing the same. Maybe a head gasket ? I had issues with the exhuast flappers about four years ago.. I installed the updated ones... I checked them, and they looked fine. I also read in a repair manual that the exhaust manifold/ riser needs servicing after 300 hours...They gave 4 reasons for water in the combustion chamber, and this is one of them, saying corrosion can let water in this way...They also mentioned loose head bolts, a head gasket, and the worst a cracked block. I changed the oil last fall, and it is not contaminated. I am a heavy equipment mechanic....I don't know anything about the exhaust system on this motor...How does it work ? Any help would be a start.
Terry
BAYLINER185
Re: 1995 4.3 Mercruiser
Terry
Somwhere on here very recently DON S posted a cooling diagram. It would be what your asking for. I dont see a search feature on here or I would have looked for it and posted it.
Give Don a second he'll be along with the answer. This guy knows his SH^&
All I can tell you is that water flows through the risers then through the manifolds and then down the Y pipe and out the prop. Along with exhaust gas. ( very basic description )
DockedPay
I thought the Don S diagram was so helpful I wrote down the thread...use the search for "cooling question mercruiser"thread by "Al Slowhand"
Terry Brown
Thanks for the reply.....I will do the search and maybe see how it works....
thanks
Terry:)
