kbait
- Nov 13, 2007
- 2,480
Newer rebuilt long block installed 2017 and has run normally until this spring. Runs flawlessly until 4200 rpm, then seems to cut out partially and a few pops. Advancing throttle to wide open makes symptoms decrease, but still not right and rpm gets to about 4500.
My mechanic buddy assumed a lean issue..so we kitted the 2 barrel mercarb. Test = same issue. It doesn’t seem to be emptying the bowl, so we ruled out fuel, and assume an ignition issue. We checked timing, swapped out cap/rotor and spark plugs mr43t gapped to .035”. Tested same. Replaced coil w/proper Sierra, no change. Disconnected shift limiter switch..no change. Any ideas? Maybe someone has chased this gremlin before..
Pickup in distributor looks new, and not sure if replacing that would solve issue. Perhaps the ignition module on side of distributor is faulty, and advancing spark too far at that rpm? Any help/clues appreciated? Thanks.
