- Jul 18, 2011
- 19,108
Re: 1995 Crownline 202 BR Deck Restoration
This rope method is to create a channel for water to drain if ever needed? It might work, but it might not, as the foam will have a good grip on the shape of the rope, and the grease coating may not matter too much. The fact that the chambers have limber holes should be good enough for drainage. If you did want to form a channel, you could make a tube of screen material and put it in the bottom of the chambers. When you pour in the foam, it will tend to stop and set up when it hits the screen mesh, leaving a channel.
Just my thoughts.
tpenfield,........... ok, I'm beginning to cave on the foam idea..... The problem is, I will actually lose sleep over the idea of not having the structural, sound deadening, stabilizing, life saving, puncture rectifying, liability erasing, magical foam back in there. I could have sent it to the local boat yard and paid them to put a band aid on it for $3,000.00 and be back to the sand bar sipping a cold one. However, like many of you, I need to be at the sand bar sipping a cold one knowing that my boat was built right. It's a curse...
Here's my plan:
The limber holes are staying in as they will at least give the foam a chance to dry out if it ever does get wet. What if I took 3/8" rope and covered it in vaseline or some kind of grease. I would insert the rope into the limber holes and then along the bottom side of each cavity. The ends of the ropes would stick out into the fuel tank area. Once the foam hardened I would yank the rope out and there would be a small channel on the bottomside of each cavity to allow water to drain to the bilge when parked bow high. Think it would work? I think I may have read this idea somewhere. It seems to be the most logical idea over pvc drainage, balloons, dissolved paper mache... etc.
Either way the foam debate is over, just don't tell my wife that it's going to cost more.
Just my thoughts.
