Jerry_NJ
- Aug 23, 2010
- 250
I thought I put a post up on this subject yesterday, seems not. Since I have downloaded a 1998 Yamaha 9.9 User manual, there was nothing available on anything older - I can see differences physically between my Yamaha and the 1998, still I assume from other experience I have with OMC outboards that the 1995 Yamaha has a pilot hole which shoots a stream of water out easily visible to the operator to let it be known that the engine impeller is circulating engine cooling water. The 1998 manual shows the pilot hole to be on the engine lower pan and on the right had side (looking forward from behind the engine). This manual also states that the operator should check for this flow which must be present anytime the engine is running (any gear) and the lower unit is in water.
I have a new looking 1995 Yamaha that I took to the lake for the first time yesterday. I purchased knowing the engine was very low hours and had not been used in many years. I made the argument on my offer that the engine appears to be low hours, but that doesn't make it the same as new, in fact I suspect the cooling water impeller may need to be replaced. This was taken into consider on my purchase so I am not disappoint if I have to replace the impeller.
But, here's what happened at the lake. It was a cool and cloudy day with the air temp about 60 degrees, I'll guess the water was closer to 50 degrees.
I started the engine and did not see the cooling confirmation stream. I shut down and mentioned it to another boater who was launching a boat with a newer 4 Cycle Yamaha. He said he also owns an older 2 cycle and said that engine has a thermostat and shuts the water off until the engine gets up to temperature, at least a couple of minutes. He asked if my engine was overheating from the brief time I had it running. I said no. He said let it run for a few minutes. I removed the cowling and started the engine (easy starting engine, and quiet) and let it run. After a few minutes I splashed a few drops of water on the engine, the water just ran down the side of the block, no steam, nothing even suggestion hot. I shut down and touched the block with my hand and it was no more than a little warm. So I started the engine up and ran it for perhaps 10 minutes getting to a backwater area where I could operate on my electric motor and fished for 20 minutes or so. I then restarted the engine and returned to the launch area. Still no pilot hole water stream. I again checked the engine temperature with a splash of water and then with my hand.
I then looked for the water intake, which both my experience with other engines and the 1998 manual, on the lower transmission housing, on either side just above the anti-cavitation plate. I didn't see any, the only intake lookiong area I saw was on the bottom of the anti-cavitation plate.
I also noted a hole in the back of the lower unit housing just below the engine level that passed exhaust gases when the engine was running. At one point I though that was the pilot hole. I have to get back to look at the engine to see if I can find the pilot water jet hole.
Looking for advice on checking this engine out as far as the cooling is concerned. The engine runs well and is more quiet than my past OMC engines (best I can recall). Is it possible the engine is running cool without water circulating, or is it possible the water is circulating but the pilot hole is plugged. I can try to clean the hole, with what, a wire?
Again, I would appreciate a confirmation on the location of the pilot hole, that one should see a water jet any time the engine is running, and where the cooling water intakes are located.
Thanks,
Thanks,
