1995 Force 120 will no longer idle
beepx2
Last year I had great use of my Trophy 1802 with the 1995 Force 120. I had replaced plugs, fuel pump, filter, fuel line, I run from an external tank with non-ethanol fuel. I was able to adjust the idle perfectly last year, properly fitting the idle screws at 1-1/4 turns. and adjusting the idle stop to get about 800rpm warm idle in the water. Last fall, I was running as normal, and suddenly it would not idle. When I slowed down to idle in gear it would slowly drop revs in gear and sputter out after 5 secs or so. To start it I would need to set the throttle high, but then when I reduce it to engage gear it would stall. It still performs fine at full speed, revs to 5000 or more, and provides full power. Compression was even at 120 last time I measured 2 years ago. I think the engine has relatively low hours.
I removed and disassembled the carbs, and noticed two things: The floats were set lower than spec by about 10 degrees or so, such that the fuel level in bowls would be lower than spec. I also noticed that in one of the carbs, the main nozzle was completely unscrewed and just fell out when I unscrewed the float bowl bolt. So I screwed in back in.
I've reassemble the carbs and reinstalled. Engine starts if I set it for high throttle, but when I slow it down to idle it will still sputter out. I also noticed that at low rpm as it is sputtering and before it stalls, it is pulsing sprays of fuel out the top carburetor, which accumulates and is dribbling out of the carb throat. (this does not seem normal)
My theories:
1) somehow the needle valve on that carb isn't closing, and the fuel pump is pushing fuel up the main nozzle into the air flowing through the carb throat. Maybe I messed up by adjusting the float angle. Theneedles and seats looked fine when disassembled.
2) There may be something wrong with the reed valves such that I'm getting airflow back through the upper carb. (I've never worked with those before)
3) when messing with the carbs I may have damaged the idle tube(s), bending them around while tightening the main nozzles.
Any ideas what to try next? I'm stuck. I installed a new starter today, which spins and starts the motor quickly. The motor is on a boat in my backyard, near my workshop where it is easy to get to.
Thanks!
jerryjerry05
Fuel out the front of the carb: could be the fuel pump is bad? the float stuck?
It sounds like the motors sucking air from somewhere.
You had the carb apart. Reset the float: carb upside down- the float should be even with the carb body.
Inspect the needle: solid tip?=the bowl inlet where the needle sets, there's a rubber o-ring that could be missing?
Needle with rubber tip: tip should be smooth and no grooves.
Starting fluid test. Get motor running, spray starting fluid around the intake side of the motor: this includes under the carb and around the packs/coils and by the 4 port covers and anywhere the air might get in. The gasket under the port covers are thin and get sucked out of position and allows air to be sucked in making for poor idle.
One tiny backfire, cough or stutter can blow the port cover gaskets.
beepx2
Well I pulled the reed valve blocks and I see that one valve is missing, many are cracked or chipped, and they all hang open a bit leaving an air gap. I'm surprised it ran at all like that. I imagine I was getting little compression in the top two cylinders at idle. I think I'll replace them first and try running it again. I know for sure floats weren't stuck and fuel pump is working, and the needles are rubber tip in pristine condition. Any suggestions on reed valves? Original were stainless, I don't know how long they lasted. The valve blocks and mating surfaces are all OK. Thanks for your input, Jerry.
Mc Tool
Master Chief Petty Officer
A not very good tuners trick is to bend the reed stoppers so to allow the reeds to open further . There should be a spec to set the stoppers . It is possible that a po has bent the stoppers ,this wont help longevity of the reeds so maybe look into this before replacing reeds.Screenshot_20250430-090321.png
Just found these boys . Fibre reeds are said to be more responsive and they dont destroy the motor if one gets loose.
Make sure the broken remains are not stuck inside the motor ......they like to hide in a transfer port and jump out after you have rebuilt the motor .🙂
Nordin
Replace the reed valves with new stainless steel valve paddles.
They will last for a very long time.
In mid 90.es they replaced the stainless steel ones with plastic typs ones, but in my experience they do not last as good as the stainless typs.
You might find used ones at Ebay or buy new ones.
jerryjerry05
Good find!! The reeds can actually be opened a tiny bit and not affect performance.
But missing that's not good.
beepx2
I saw that carbon set on ebay, but something is wrong as the picture shows sets of 5, and my motor has sets of 4. I couldn't find any stainless ones, only full valve block assemblies. I ordered a set of fiber ones from CCMS, which look correct in the photos (Link below). How might I find the right spec for the spacing of the stoppers? It's not in my Force service manual. A mystery to me is how long the reeds have been broken. I recently put on a new prop which lets the engine rev to redline at WOT, so maybe that did it. I will look for the broken bits in the motor before reassembly. I plan to use a bore scope through the plug holes, and in through the gap where the valve blocks go. Is that the transfer port?
Many thanks for the help guys!. I will post some pics of the broken valves, and let you know what happens with the new ones.
BTW the starter had been turning slowly and heating up the cables. last time a bit of smoke came out of it after a lot of hard cranking. I bought a new starter and put it on, and the difference is like night and day. I should have done that a long time ago. Piece by piece I'm refreshing this motor, hoping that eventually it will be reliable: Plugs, fuel pump, filter fuel line, rectifier, impeller, prop, rebuilt the tilt drive motor. I like how simple and easy to work on it is, and how cheap the parts are.
Mc Tool
Sometimes ebay just has a generic pic of an item ,usually small print says "actual item may differ from pic " but yeah , sorta puts a bit of strain on the confidence ( I have a set of rings for the "other " 4hp Yamaha )
beepx2
Update: News reeds are installed. Kind of an easy job, my first time doing it. 9 of the 24 old reeds were chipped or cracked. One was half gone.
Reattached the carbs, and she fired right up. No gas leaks. Idles fine at 900-1000 on the muffs, but when I go lower it idles rough or dies, although the motor was cold at that point. I tweaked the idle screws to no effect. In the past it idled nicely at 800 rpm in the lake. Next I will check the timing to see if it's out of spec. The new starter really spins that motor like crazy, what an improvement - I should have bought that first thing.
jerryjerry05
NOT IDLE screws. while they will affect the idle thats not what they're for. They're for air/fuel mix at low rpms. The idle screw is on the towershaft. Set the air screws at 1 and 1/8th turn out. Then adjust from there. Once you get it running, do the starting fluid test. Start the motor, spray SF around the intake side of the motor. Around the base of the carbs and base of the coils and packs and around the 4 port covers. If spraying makes it run different??? then it's sucking air somewhere???
beepx2
Great success today. Reset the timing to 29-29 deg BTDC, it was adnaced about 4 degrees too much. Reset the throttle linkage, it was only opening about 3/4 before, and set the idle with the stop bolt thing. Boat ran GREAT at the lake, amazing power. I now need to order a new prop with more pitch, partly because I run light with an unpainted bottom, an half tank or less. The reed valves were really the key here. I will try the starting fluid test next run, just to be sure.
jerryjerry05
YEA!!! sounds like your getting there.
Another test: run the motor and get it hot, then running at full throttle turn the key off, don't throttle back just kill the motor, then pull the plugs and check the burn. Check for all 4 plugs being the same burn.
beepx2
One more question. Should the over-heating buzzer sound sometime during the starting sequence? It doesn't now, though the buzzer sounds when I put 12 volts to it, and also buzzes if i jumper the connection at the motor sensor. (as I recall) A lot of motors do that, but mine doesn't. I 've rewired just about everything, so I may have missed something.
tg3690
These old motors don't have all that fancy diagnostics stuff. So it should only go off when grounded (testing) or it is overheating. I test mine by using a screw driver and ground it to a spark plug.
jerryjerry05
The buzzer shouldn't sound when starting. Only when 12v is applied.
If it buzzes when 12v is applied?? then it's doing the right thing. Should only sound when voltage is sent to it.
beepx2
My no-idle problem is back. I've used the boat half a dozen times recently, with more or less no problems. On a two day outing, near the end of the second day, the boat was idling, then slowly decreased in RPM then died. Now it will not idle at all. When I set the control to open the throttle a bit in neutral to start, it fires up and runs at 2000+ RPM (on muffs). Then I throttle back to 1500, 1300, and when I get down to about 1000 rpm it stops dead. When try to start it that RPM it won't fire. I must reopen the throttle more for it to restart. I had guessed that maybe the idle circuit was clogged so I removed and cleaned both carbs, making sure all passages are clean with carb cleaner. The floats are set right, the needle valves are rubber-tipped and look fine. All the jets were clear and unclogged. I added a water/fuel separator, and emptied all the fuel lines. I didn't see any debris anywhere during the cleaning, or any debris in the filters.
Still has the same issue. It even runs a little rough at 1200 rpm. Last year it idled very smoothly at 800 rpm or so, so this problem is new. Earlier this spring I reset the timing and replaced the reed valves, and it ran great. All the bolts for the throttle stop and timing mechanism are still tight.
I'm puzzled at what could be wrong. It ran and idled great for months, then all of a sudden it won't. I have now tried turning the idle screws: they are set out at 1 1/2 turns. I screwed them in and out a bit with no change. I'm wondering if it could be ignition wiring, spark or timing, or something other than the carb idle circuit. The primer bulb is firm, the filters show fuel is present, and there is no fuel coming out the front of the carbs. For reference, the fuel pump and starter are new also. Any ideas of what to try next?
beepx2
I've been thinking about it more, and researching, and today I'm going to work on it with the assumption that the carbs are not the problem. I'll be checking the ignition circuit and wiring, starting with checking for spark when starting with the control lever in the neutral position. I've had trouble with the lockout switch, and the wiring is a bit of a rat's nest with some cracked wiring and many crimp connectors. maybe the throttle lever position is causing breaks in the ignition wiring. There are some times when the ignition doesn't work for no reason, and moving the lever back and forth a few times clears it. I'll also recheck the timing.
jerryjerry05
No idle: fuel pump diaphragm, sucking air somewhere.
Sucking air: Try this: start the motor and spray starting fluid around the intake side of the motor. This includes the area under the coils/packs, at the carb bases. If the spray makes the motor run differently then it's sucking air.
The 4 port covers are a good spot for the air to get in. The gaskets are weak and if the motor coughs, sneezes, backfires one time ?? This can blow a gasket and it can suck air.
cyclops222
Fuel pump is dying. It will keep getting worse. Then die totally. Been there. I rowed about 1 mile.
I bought a pump repair kit by Evinrude. Opened the fuel pump over a white towel. Took kit and towel to my Evinrude dealer. Way to many parts and instructions.
