Hello All,
Same motor as I was working on before. 1995 force 90 Hp S/N OE104323.
I have replaced the head gasket as it was leaking between #'s 2 and 3. Still getting water in those cylinders.
Complete new water pump. I hook a garden hose to the lower end of the water tube and nothing comes out the pee hole. after a minute or so with the garden hose connected I start getting a lot of water out of what I take it is the exhaust but nothing out of the pee hole. Water pump is assembled correctly.Why no water out of the pee hole? Also installed a CDI regulator and now I cannot turn engine off with either key or Emergency kill switch. I have a black/yel wire unattached to anything.
It is located between the regulator mounting plate and the block on the right hand side. Where should it connect?
How do I check for a cracked block without pulling the powerhead? I have not taken the exhaust chest cover off as I see a lot of horror stories about bolts breaking.
Thanks in advance for any and all help.
