Won't start, no spark on any plugs. Ran just great yesterday, now nothing. New plugs gapped to .06, new battery, less than 1 year old plug wires. Starter turns, but no fire.<br />Any suggestions?<br />Thanks, <br />Mike
if it has a single switchbox remove the blk/yellow wire and retest. if it sparks find the short to ground on the blk/yellow wire. if it does not then use an ohm meter to check the low speed charge coil of the stator, stator failures,especially with a black stator, were common.
