1995 Merc 3.0
Keith Ogden
Ok so I am going to replace my plugs , cap , rotor and wires due to what looks like a slight miss and idle.
Boat is new to me (7/4/16) .
I want to check the timing after , before I take it in for a tune up. But the timing marks are gone. The metal tooth plate is there but no markings.
All the paint has lifted off .
Any one have a picture so I can verify the timing before I take it in ..
Serial Number F371910
s.hadley81
No Title
This might help! I always mark the notch with a piece of white chalk to make it easier to see. Also if you clean the tab up real good you might see them because they are stamped in the metal.
Alumarine
I had a similar problem.
Once I cleaned the timing marks up with a wire brush so I could read them, I then covered them with clear nail polish.
alldodge
If you have points or DDIS ignition timing is set at 8 BTDC
If you have EST it is set at 1 BTDC in base timing mode
Keith Ogden
Just looking to double check. If it's off I will have a proper tune up done . I know the carb needs adjusting ( I messed with it ) trying to get the RPM's down .
But at low RPM it moves a bit much for me , looks like it might be a miss.
I hope the plugs and stuff might fix it.
I just re-pluged and drilled the front motor mount out as it would not tighten.
Checked it out with an endoscope and the wood was dry and yellow so no rot. I think it my have just vibrated the screw out a bit.
Just don't want to chance that the timing was off and caused undue vibration .
Make sure you check your alignment
Keith Ogden
Alignment should be just fine . Bolts where holding but felt like they could not be torqued down. Removed , drilled , plugged and replaced one at a time . never had to move the mount .
Keith Ogden
No Title
OK parts replaced. Guess this cap would be an issue .. LOL
No wonder it seems to have a miss ...
Plus they had MR43T plugs ( short ) Plugs looked good other then short and gaped at .042
Keith Ogden
SO I had to replace the starter as the PO had a car starter installed. Did it my self , not bad at $65
Just got it back from the shop after having a water pump kit installed . What a rip ! $156 for a kit better be GOLD plated ...
But I will say he fixed my speed-o , speed-o coupler (?) was bad . Only cost $18 for the part.
1 hr 50 min labor for water pump kit , speed-o coupler and pressure test.. not bad .
Had it in at a different shop 3 weeks ago and had a ( tune-up) . Timing was spot on but they had to adjust the carb. $98 no parts .
Idles very well now . No miss at all . $98 well spent .
