Can you check the pulser coil with it still on the motor? the motor has no power carbs cleaned and adjusted new feul pumps. with the high idle lever the motor will rev to 5900 but put it in the water and 2400 and sounds boggy. it wants to die at idle. if you catch it before it dies and tap the electric choke it will run for a few more seconds then try to die again. I checked the oms on the pulser coil as per the manual all three omes readings came back as follows 140 138 140 this was with the coil still installed. getting fire to all plugs. I am lost I just bought the boat last week and have yet to get it to runn right. new fuel. compression 96-100 on all cylinders. timing adjusted per the manual. one plug wire was out of spec and I trimmed it back and is now testing good. new NGK plugs gapped at 38 thou. I was told that someone had rebuilt the carbs 2 years ago. to me it acts like fuel starved runs when the choke is tapped fuel line prime bulb gets firm. filter seperator emptied and was clean no water. the jets inthe float bowls are 2 different number jets oen is a 130 th other looks like a 126 or 136 with one goes on the port side. I put the 130 on the staboard side just like it came out but I was not hte first one to have them apart so i was just wondering??
I know there are a lot of questions here but i just tried to be as clear as possable on the thing that i have done. any help sugestions would be great.
