1996 120 Force Carburetor
jph1996
Does anyone know if there is a replacement carb model for the tc-119a and the tc-120a tillotson? As we know you cannot get these anymore. I have a tc-119a that I had rebuilt and then I did it myself because it just does not work correctly. I am thinking that it never work correctly and previous owners just lived with it.
Reeds and fuel pump are all good. Runs good at middle and upper rpm. At idle runs rich and mixture adjustment does not have impact on engine performance at idle. Bottom carb adjustment acts like it should.
Everything else about the engine is great so I would like to upgrade the carbs if possible.
Any ideas?
Thanks,
-Jeff
roscoe
Re: 1996 120 Force Carburetor
Don't know of any upgrade, replacement, or retro-fit.
Looks like these carbs are still available from
Best bet for a cheaper one, is ebay. Always confirm part numbers with the ebay seller.
I think 1992 and newer used the 119 and 120 carbs.
jph1996
roscoe,
looks like your post did not come through with where you found the carbs. I know that iboats does not carry them so I don't think they will mind if we communicate about where you did see them available. If you could PM it to me or email me at herteljp@yahoo.com, I would appreciate it.
Thanks,
Jeff
