SparkieBoat
- Aug 17, 2009
- 3,643
I just got in a new CDI stator. 173-4981
The old stator test were on the 6 wire plug from the stator to the power pack- Brown/Black - Brown/white = 280 at idle and did not change more than a few volts at WOT. orange/black - orange = 20.5 maybe 1-2 volt fluctuation through out RPM ranges. Brown/yellow - Brown = 292. Orange wires going to coils were all 280-290 never going above 300 at all RPMs. same readings with rectifier disconnected. The new stator readings are- Brown/black - brown white = 289 with only a few volt gain to WOT the Orange/black - orange = 20.5 with little change at WOT. the Brown/yellow - brown = 280 with only a few volt gain at WOT. the brown wires should be at 400 V at idle according to the CDI guide I read. the Orange wires from PP to coils were all around 212 at idle then up to 228 at WOT nothing passed 230. CDI guide says they should be 150+ at idle then rise rapidly with RPM increase to 300-400 V. all readings were the same with Rectifier disconnected.
My question is have I gotten a bad stator from them or is there something else that I am missing??? Before I called the supplier I wanted to be sure.
Thanks for any input and I have included the link to the CDI guide. http://cdielectronics.com/downloads...oting Guide 2009 - OMC 6 Cylinder Optical.pdf
And the flywheel magnets looked ok to me. I can post some pics if you need.
Thanks again , Sparkie
