1996 26 foot wellcraft excell prop size and pitch??
I just bought a 1996 26 foot wellcraft excell and it has the incorrect prop on the boat, I cant even find any numbers on it. I am trying to find out the right size and pitch I should be running before purchasing a new one, expensive. It has a 454 with a bravo 2 drive.
Thanks in advance
steelespike
Re: 1996 26 foot wellcraft excell prop size and pitch??
Have you checked under the prop nut for numbers?Do know the present max rpm and speed?A prop shop can measure it for you.
found a part number on my prop, can anyone decifer it for me
18-18622448 25p
18-18622448 25p
Ayuh,... It's a Merc. prop in 25" pitch...
That's probably 48, not 18, starting the #....
180shabah
We need the information listed in the Read This First sticky before we can begin to suggest props.
642mx
Thanks in advance
Give Brett or Brad a call at BBlades. They'll know exactly what to put on it. They also have a prop test program so you can try a bunch of them before you purchase. http://www.bblades.com/
I will give BBlades a call, here is my boat info if it helps with any suggestions
1) Performance issue you are trying to correct.
Havent put in the water yet, but I dont think a 25 pitch prop is correct
2) Current prop manufacturer, model, aluminum or stainless and as a minimum.
Dont know manufacturer, it is aluminum
3) Current prop diameter and pitch (required).
Dont know, I will try to measure diameter tomorow
4) Wide open throttle RPM and speed with an average load (very helpful)
Max for a 454 about 4500rpm???
5) Engine/drive make, model, year, and HP
454, bravo2, 1996, 300
6) Boat make model, year, length and weight
Wellcraft excell, 1996, 26 foot, 5500lbs approx
I hope this info helps, wish I had more. sorry
Ayuh,... I guess you're Done here,... Atleast til you splash it,+ come back with some #s.....
180shabah
This needs to be measured, a guess is useless.
I am going to try to get the boat in the river tomorow evening and will get back to you with some more information. I had to replace the water pump or it would have already been in.
Put the boat in for the first time this weekend and with a clean bottom and 4 adults, full gas, and no waste or water and it ran pretty good with a 17.5in
25p prop on it. It maxed out at about 4300rpm. On the engine cover it is rated at 4200-4600 max rpm. Should I prop down a little bit because when the bottom gets dirty and the boat gets loaded with **** it will be slower.
steelespike
The rpm doesn't mean much wuthout the speed but::
Probably "prop down"But run it a little to see how it responds to a load.It will give you a better idea what you need.
Sorry forgot to post speed,
45 mph on gps at 4300 rpm WOT
I want to buy another prop and use this one as my back up.
