Re: 1996 70 HP Evinrud
Forget about the sensor as stated before it will not shut your engine off if it get hot, it will put the engine into s.l.o.w and sound the warning if everything is functioning propperly. (the white black wires are for quick start and again will not shut the engine down). when the engines dies will it instantly turn over again and turn over fast? If so you can just about eliminate the engine overheatiing and running without oil. A engine needs 3 tings to run. Compression -fuel -igniton. If you have compression and spark, it has to be fuel. You indicate that a shop wants $100.00 per hour to look at it. An hour in the shop can get a lot of answers, how many hours do you have in it now?
