Is there no way to flush this motor other than in a barrel? Thanks.
G GasCan II Petty Officer 1st Class Joined Jul 15, 2010 Messages 281 Apr 15, 2014 #1 Is there no way to flush this motor other than in a barrel? Thanks.
D Daviet Fleet Admiral Joined Sep 24, 2008 Messages 8,958 Apr 15, 2014 #2 Re: 1996 8 Hp. Evenrude If the lower unit does not have a flush port, you are going to have to run it in a barrel. What is your model number?
G GasCan II Petty Officer 1st Class Joined Jul 15, 2010 Messages 281 Apr 16, 2014 #3 Re: 1996 8 Hp. Evenrude Daviet; The mod # is EBREDD serial # is 03808996. Also what manual do I order ? Thanks ! Last edited: Apr 16, 2014
Vic.S Rear Admiral Joined May 4, 2004 Messages 4,720 Apr 16, 2014 #4 Re: 1996 8 Hp. Evenrude GasCan II said: Daviet; The mod # is EBREDD serial # is 03808996. Also what manual do I order ? Thanks ! Click to expand... It's a two stroke model. The four strokes can be flushed with muffs ITYWF but not the two strokes But check the model number more carefully That's an "8", for 8 hp, not a "B" Also suspect final letter may be "S" not "D" although it is only a manufacturing suffix. What manual do you want Owners manual or Workshop manual . Former avaialble from http://www.outboardbooks.com/ Cannot help with workshop manual but maybe something of use at http://boatinfo.no/lib/library.html# Last edited: Apr 16, 2014
G GasCan II Petty Officer 1st Class Joined Jul 15, 2010 Messages 281 Apr 16, 2014 #5 Re: 1996 8 Hp. Evenrude Vic.S; Thanks for the help !
