So i did my carbs a few months ago and the boat ran great for 3 outings. It was giving a sputter at trolling speed every minute or so and I turned the fuel screw to 2 turns out and it went away (suspect it was a lean sputter?). Today after trolling around the creeks for a few hours it started the sputter again so i tried to get on plane and it was cutting out badly could not do it. I let the motor cool and switched fuel tanks and didn’t help. Got progressively worse to the point i barely made it back to the dock: The fuel is only 2 weeks old ethanol free with treatment in it. I did notice the middle carb seems to have a slight amount of fuel leaking from the float bowl seam/drain area (weird bc all new gaskets) but it didn’t seem to be coming from the vent (stuck float). Upon bringing it home i lowered the motor to flush and it started and ran great with a higher idle. Revenge slightly did not bog out but of course there was no load. Could be bad fuel (but unlikely) or moisture in filter but l looks like i’m going to have to pull apart the carbs which is crazy after less than 10 hours. Any ideas and would i have to get all new gaskets again? The look nice and new/green still. Btw i let the motor cool down on the water just too rule out an issue with heat (air leak/ignition coil) and it did not help.
