sandcrab277
- May 31, 2004
- 6
we've followed the repair manual to remove the lower unit and determine why the unit is making noise when shifting from neutral to reverse...total of 5 nuts removed...according to the book, it should come right off....it appears to be frozen and gentle tapping with a block and hammer on the inner part of the fins near the studs doesn't help to loosen it...the port side seems to open a small gap but no success on the starboard except forward of the front stud...any suggestions would be appreciated...this unit has never been apart before so there may well be corrosion internally...we've sprayed with pr buster...
