1996 Mercury 115 Rev limiter?
Status
Not open for further replies.
EMC 1810SS
How is the rev limiter wired on a 4 cylinder 115? I cant seem to find a wiring diagram that shows it anywhere and the only place I can even find the part number is on the BLOCK part number diagram from mercury. Nothing in electrical. Any idea?
Re: 1996 Mercury 115 Rev limiter?
Rev limiters can be internal to the switch box on the ignition.
carholme
What is your engine s/n?
If you have the service manual, you can see it as item l under ELECTRICAL - 2D-7 and 2A-25. If you do not have the manual, see my message to you in Notifications at the top of this page.
Gerry
EMC 1810SS
I have the manual but my 2D-7 shows power trim schematics?
carholme
What is the revision number of your manual? The basic Merc manual is 90-830234, then there are the revisions, R01, R02, R03 and R04.
R03 shows the wiring diagram under 2D-7 and 2A-25 is a description of the circuit
Gerry
EMC 1810SS
90-13645?? That's the number at the bottom of the cover. Being a PDF I am not positive. Its for the 3 cylinder 70-75-90 and 4 cylinder 100-115. Does that sound right?
carholme
90-13645-2 is not the one you want, which is 90-830234.
90-13645-2 only goes up to s/n 0A997142 thru 0D283221.
PM sent.
Gerry
wired247
Whats that? Mercury serial numbers do not have asterisks.
This isnt your social security number. No one is going to track you down and empty your bank account for posting your motors serial number. Mercury serial numbers are one offs and one number different throughout the whole thing will put you in an entire different engine family but if you want to look ANYTHING up in the mercury system you need all the numbers.
Faztbullet
Never seen a rev limiter on the 115 prop motors, only on the jet models......
EMC 1810SS
You only need the first 3 numbers to find the proper range. The rest are irrelevant. The asterisks are numbers but being like a car serial number, I really don't want mine all over the net. You never know who is looking.
EMC 1810SS
PM sent.
Gerry
Thank you! You are right, mine was outdated.
carholme
Well let us know when you see the sections I was referring to as others seem to think it doesn't exist.
Gerry
wired247
Sucker don't want no help, sucker don't get no help.
EMC 1810SS
Gerry
I found it and now have the EXACT information I needed. I also have a huge amount of additional info that I am still absorbing. What a great resource. Thank you for your assistance!
Status
