1996 yamaha 150 saltwater ignition problem
strokerace
hey guys, I'm not getting any fire on cylinders 2, 4, and 6. I have both of the multifuntion gauges out of the boat. I know the engine has will lose rpm's if it over heats or gets low on oil. will this engine run with out those gauges?
rodbolt
Re: 1996 yamaha 150 saltwater ignition problem
2,4 and six with no spark tested with a spark tester?
that will mean you lost an entire bank, usually means CDI failure.
very expensive.
test the inputs to and the out puts from the CDI with a peak reading meter or a DVM with a DVA adapter.
motor will run fine with or without the guages.
but dont rely on the pull a plug wire method use the correct meter and the tune up spec guide or service manual.
