1997 135 hp Merc. outboard- electrical problem
spetrie
Hi,
I aquired a boat with a 135 black max. The previous owner had the engine quit suddenly after 2 hous of smooth running.
I am assuming that the problem is with the electrical for the fuel or the ignition. Are there any known problem areas with any electrical components of this engine or does anyone know of probable causes?
Thanks, Scott
Chris1956
Re: 1997 135 hp Merc. outboard- electrical problem
Scott, the only known problem is that the VRs tend to overheat and burn up. The ign systems is a proven design, not to say that nothing ever goes wrong with it....
CharlieB
Start with basic troubleshooting
Compression test to verify mechanical integrity of each cyl
Spark test using an adjustable gap tester set to 7/16 inch to verify the stator, ignition module and coil, operation. A DVA test of the stator is also advisable to verify the condition of the High Speed windings in the stator.
Test Fuel Pump Output, clean carbs
Water pump impeller
Gear case oil, pressure and vacuum test if any water found.
Then crank it up!
