1997 150 runner trim/tilt help!
rat"BASS"tard
Looking for the proper procedure for changing the fluid in trim/tilt pump on
my 97 150HP. runners. Looked in Manuel but had no info at all.
any help is greatly appreciated Thanks..... KT
Chris1956
Re: 1997 150 runner trim/tilt help!
Normally we do not change the PTT fluid, hence the missing procedure. If you really want to change it, you may be able to take the PTT unit off and dump it out. Otherwise, just top it off with ATF.
