jonnysteals
- May 26, 2009
- 56
I have an 1997 evinrude 90 spl 2 stroke that i have to premix the gas(no auto mixing with seperate oil tank). I have an issue with the battery draining. My temporary solution was to add a battery switch to turn the battery off. I completely rewired all the lights and center console. With every electronic disconnected from the battery except for the outboard leads the battery dies. So this isolates it to the outboard itself. As soon as I connect the outboard connections to the battery the battery charge drops a .01. I start the motor and disconnect the motor from tha battery and it stays runnign fine. This means that the motors charging mechanism is functioning correctly. I replaced the starter solonid and its still draning battery's.
Anyhting to look for would be great. I love this boat except for this electrical issue. If I can not figure this out soon I am going to start pulling fuses one by one to try and isolate the problem. They problem with that method of detection is well its time consuming becuase the battery drains over time and not noticible instanly. Thanks in advance for all they help
