1997 Force 50 HP voltage regulator
ilmk27
I bought a aftermarket voltage regulator for my 1997 Force 50hp and the wires coming out of it are 1-red, 2 yellows, & 1- black, on my old regulator I have 1-red, 2-yellows, & 1-gray. I know where every wire goes except the black. does it go to the gray wire? the regulator is one I seen on here (Universal Regulator/Rectifier 01-154-16) that someone else used on there 1997 50 HP & it worked great. Just not sure if I need to hook the black to the gray or not? all the other wire colors match.
Jiggz
Re: 1997 Force 50 HP voltage regulator
Yes, the black wire hooks up to the gray wire which is the negative terminal or ground.
ilmk27
Thanks Jiggz!!! So the gray wire that goes back to the tack is a Negative or Ground correct?
Jiggz
No. Except if you use this aftermarket unit the black wire goes to negative or ground while the red goes to the positive of the battery ckt. The gray wire now has to be connected to one of the yellow wires as signal input to the tach.
ilmk27
Thanks! does it matter what yellow wire I hook it to or will it work on either.
Jiggz
When I did mine, it was a matter of luck. But if it doesn't work on the first yellow wire it should work on the second. And same thing happened in my case, I have to switch it over to the second yellow wire. It's still a puzzle why this is but hey, it works so I just left it alone and charge it to experience.
ilmk27
Thanks Jiggz! I will try this and hope fully I will get lucky on the first try. If not I will switch to the other yellow wire. Again thanks for all your help.
ilmk27
Changed regulator everything working good now. 14.2v at battery while motor is running!!! Thanks for every ones help!!!!!
