Quick question folks,
My unit is leaking out of the top seal. I can live with a small leak but this one is quite large. As many others have posted, the top pin is impossible to get out. Three straight days of PB Blaster, heat and hammering have not gotton it out. That said, the bottom rod came out with ease. My question is if I can get the cylinder cap to unscrew, I assume it is possible to remove the unit with the ram still attached to the engine bracket, rebuild with new seals, and insert back into the unit? Any insight you can offer would be appreciated. thanks,
Maury
Maury
