1997 Marine/Mercury Tracker Pro 60
Chicago4200
Hello everyone, I need help or a recommendation with finding a temp sender sensor for our 1997 Mercury Tracker 60HP. I want to add a temp sender along with a Temp gauge. The sender must work in the 200-ohm range.
GA_Boater
Do you have a gauge and sensor now, but you need a new sensor?
Chicago4200
I do not have a temp gauge. The only temp sensor in use is the one connected to the warning horn.
Chicago4200
Here's a picture of my engine.
Chicago4200
Nevermind. I found a sierra temp sending sensor that I threaded into the block. Everything is working!
Chicago4200
I'm asking because there are two different sized plugs on the manifold. The only reason I was looking is that I installed an all-in-one digital GPS Speedometer, digital Tachometer, Hour Meter, COG/ODO, Trip Meter, Water Temp, Fuel Level, Oil Pressure, Voltmeter. I got every gauge working too! It just took some research to find the right sensors, ohm ranges, and thread sizes. You can change colors along with other options like Knots or MPH too!
