bman440440
- Apr 4, 2011
- 266
ok to give everyone the back story my engine was running good until I started getting rod knock(water in the oil from cracked riser spacer) last trip... well I knew it was time for a rebuild so I pulled it and sent it off to (a very trusted) a shop and had it rebuilt... no major issues... had them do more than it needed... complete valve job, new standard bore pistons and rings, cylinders honed, new cam, lifters and bearings... yadda yadda yadda... get it back in the boat and go to start the break in process and it was a little hard to start... I did prime the oil system (40 PSI for 90 seconds) before starting... no biggie... but here is what it is doing now... its backfiring threw the carb when under load and is not making any power and will not go over 2000 RPM... I did set the timing at 10 degrees... but it runs rough (in neutral) at any thing below 1200 and wants to die at 800... I checked the compression 185-186 across the board... also I did not mess with the carb because it was running great before I rebuilt it... I took the intake and carb off as one unit so not to mess with anything... one thing that is not new is cap / rotor and plug wires and coil... have any of you guy's out there dealt with something like this before? any help would be great!! thanks!!
Brian
Brian
