This is my buddies boat, and I was not with him when it happened so I dont know all the specifics other then himself and 4 other people in the boat at WOT on plane hit bottom on a rock bar here in lake erie.He called and asked if I could help him get his boat out fo water to check for damages and for sure to get the prop reworked as he was sure that was trashed.<br />WE leave the dock and head for the ramp 3-4 Mile trip...The boat planes almost as easy as it did with new prop on and i didnt notice much vibration on plane... While in a no wake zone you could feel a little shimmy which was expected.....We get the boat back and on the trailer with no problems and all 3 blades have damage,definetly needs to go in the shop...Problem and questions are Im concerned with the other damages. The Skeg on the very bottom is missing a few peices and I can count at least 3 places on the lower skeg that have pecies missing... Also the lower plate (not sure of the technical name) but its the full plate just above the prop...On the side it appears the prop picked up a rock and knocked out a chunk on that plate bigger then a size of a quarter....How serious are these damages and what problems can we expect from these damages. I mentioned that the crack in the top plate could create a weak spot,but I was just guessing....<br /> On a side note.....While Im an outboard man, and not very knowledgable with outdrives,if I grab the outdrive and move it left to right it has a little play (1/4" movement or less) is this normal?<br /><br /><br />Can this be fixed? Is it a neccessity to be fixed? I myself am more worried about the chips in the plate and the Skeg more then the prop,props can be replaced everyday..<br />We have a week long trip which included the boat, planned for the first week of August so if these HAVE to be fixed we are going to push for time.<br />Any thoughts,experiences,or opinions would be greatly appreciated.<br />Thanks
