1997 Searay Engine Hatch
flyboycj84
Hey guys, the hatch on my 185 is all cracked and looks like crap....anyone know where I can find one without going to the dealer???? Used???
thanks
Don S
Re: 1997 Searay Engine Hatch
Moving to Boat Restoration and Building
flyboycj84
woops....thanks don....im in this forum so often i forget!!!
erikgreen
There's plenty of ways to make one.. or you could try finding a used one on ebay or craigslist. Do you mean the doghouse, or a deck hatch? Post a pic.
Erik
Ayuh,..... Your choices are to Rebuild, or Build New......
I believe that Searay would Laugh at you asking for parts for a 11 year old boat......
flyboycj84
The hatch seems to be made of a foam core, covered by white plastic about 1/8in thick, i have never done fiberglass work.....what would be the best way to repair it? would bondo work?
lmannyr
Master Chief Petty Officer
Is it a doghouse type or flat? Post a pic to see the damage.
flyboycj84
hey...cant get a pic till tomorrow, but it is a doghouse type at the rear of the boat that swings forward on 2 quik release hinges. It is definitly plastic....i cant seem to find a used one so it looks like im stuck fixing it
flyboycj84
heres the hatch in question......all of those black lines are cracks, this was before I had cleaned the boat up nice, and those black lines were just dirt collecting.....but they cleanly illustrate the cracks. The previous owners house was broken into, and apparently stepping on this hatch was the only escape route for the burglars....
oops!
your dog house is trashed bud.....
ok..here we go
..it is repairable either from the insde or outside......
from the inside....add a new layer of glass.....thin csm will do....then repair outside cracks with a filler.
outside.....glass from out side ...and repaint.....this will require lots of grinding
if you take it to a glass shop...they will fix that up in a jiffy for 200 bucks....
u fix ....10 hours and 80 bucks
the methods i described....are just very light descriptions of the processes....post here for more detailes exact process discriptions
Coors
Search the old threads, rodbolt, rodbuster, can't remember; figured out vacuum molding.
Other wise, build a form base, cover the existing with saran or 4 mil poly, make a mold, then build a new one, off the old mold.
erikgreen
Here's a thought - go to a boat junk yard or a marine dealer and see what they have that looks good. Doghouses aren't a precise fit to the motor, they just have to be big enough to cover it and the bilge, and fit in with your furniture.
The doghouse from another boat model from that same year, or from adjacent years may fit, or you may find one from a completely different brand and year of boat that fits. Take some measurements and see.
Otherwise, this is a good starter project for you working in fiberglass... it's not structural, so if you screw something up there's no safety issue. It's a chance to make a completely custom doghouse for your boat :)
Erik
flyboycj84
thanks for the felp fellas.....im gonna try and find a boat junkyard near Cocoa and see what I can find, if not Ill tackle the glass project. I thought bondo might work, but i know fiberglass is a lot stronger.....so I guess we'll see
lmannyr
I would remove it from the boat. Remove all hardware and trimming. Sand the areas on the inside needing the fix. Apply a layer of whatever glass. You can use poly resin (cheaper) if you want. After thats cured, sand the outside cracks and fill with filler - Bondo will work fine. Sand the entire outside surface smooth, and paint or take it to a shop to have it custom airbrushed with a heavy gloss!
HAVE FUN!!
