1998 115 (E115SLECM) VRO leaking fuel
c6mcfall
Boat has sat more than it's been used unfortunately. I see that you can get the OEM fuel side rebuild kits, any experience with these? I'd also thought about rebuilding and then just going to pre-mix. I'm more concerned that the oil portion is next to fail, so am I better off disabling the oil injection rebuild the fuel side and just pre-mix?
These VRO units are quite simple.---And there is not much that can go wrong with the oil side.-----Take it apart to see what is wrong.----Repair as needed.
Chris1956
I had the same issue. My '98 Johnny OMS pump was leaking raw fuel. Being that it was 27 years old, I replaced it.
Upon further review, the oring where the raw fuel line attaches was leaking.
c6mcfall
I'll pull it and order the OEM rebuild kit. I can't complain the thing is 27 years old, not many mechanical items these days last anywhere near that long. It will be a few weeks before I get to it, will report back with results.
Thanks for the input and help, great forum!
c6mcfall
Just stopped by the local shop I've used for years, they were a Johnson/Evinrude dealer for years now sell Yamaha.. Anyway, owner (mechanic) told me that maybe 50% of the time the VRO kit fixes the leak due to wearing on the housing, not that the parts are substandard. I have nothing to go on but what others are saying, anyone run into this before?
Crosbyman
tdon'T assume anything check out the utubes and dig in... at worst you can pre-mix.
Chris1956
You can get a brand new OEM OMS pump for $500, or a rebuild kit for $200, which has a 50% chance of fixing your issue. You pays your $ and takes your chances.
Harkonnen
Mixing gas is a pain, but at least you won't get your engine fried if VRO freaks out. My philosophy is, run VRO while the motor is under warranty, then go pre-mix. There are reasonably priced kits for that.
c6mcfall
I went and ordered a conversion pump, it was $125 from the local shop I usually get my parts from. They used to be an OMC dealer, good folks, have tons of used parts, so I usually order from them even if I pay a little more. I'm going to pull the old pump, might rebuilt it.. will see. For now I'll go with the conversion, pre-mix and hopefully get to use the boat. Hopefully will have it in next weekend, not happening this weekend.. Fixing the AC on my son's truck, always something.
