midsized johnson
- Jul 28, 2005
- 155
Well, true to form, fix one thing, then something else pops up. I went out Friday, got up to speed at around 5000 rpm and a sudden loss of about 2 grand, then bounced back up to full speed. I started thinking about it, got my son to pump the squeeze bulb and she ran fine. I assumed since my son became the fuel pump, that it must be the problem. The service guy at the shop I bought the rebuild kit told me it could have been a fuel restriction too. I went ahead and did the rebuild, checked fuel lines, everything looked fine. I was pretty sure it wasn't the fuel pump as both diaphrams looked fine on visual inspection. I did the rebuild anyway. This is a VRO fuel pump, BTW. I cleaned everything up real well in the stuff above the fuel pump, not sure what it all is, but there's a bowl with a float in it and the primer mechanism is mounted on it as well. All of it seemed clean enough when I took it all apart, but shot carburetor cleaner in it anyway. Long story short, it ran great yesterday until we headed in, then it started the rpm loss again with pumping the squeeze bulb fixing it.
I noticed a bit of fuel around the inline fuel filter that mounts next to the fuel pump and tightened it up, ran new fuel line and removed the quick connect fitting at the tank and put in a hose barb with a hose clamp. I dumped the fuel and there was no appreciable amount of gunk in the tank and nothing clogging the fuel pickup when I pulled it out. I also replaced the squeeze bulb as I figure it might be a remote possibility that the check valve was malfunctioning.
I have a manual for my year model's engine, but it's for an SPL, which appears to be quite different than my ELECM, as I found nothing about the stuff above the fuel pump.
Anyway, if anybody has a take on what's going on, and what I could have missed, I'd appreciate the input.
