Not sure just what you are asking... When you say the spark is "all good" that means you have good spark on all 4 cyls. If so, why are you now concerned about the power pack or trigger? If you are diagnosing the running issue you describe- you need to determine if the engine is dropping a cyl. Keep in mind the engine will usually run fine when cold, even with a weak ignition component. When the engine warms up, it begins to affect the weak ignition component. So when testing these ignition components, stator, timer base and power pack-be sure the engine is warmed up to normal operating temps.
