I am in the process of full bellows and gimbal bearing replacement due to water infiltration. I suspect the main culprit is a hose fitting inside the boat where the water inlet goes from the rigid plastic thru-hull fitting to the hose. To diagnose I put the boat in the water and ran it for a bit. I was able to get my head and camera back there to see a repetitive "squirt" of water originating from just above the output shaft of the motor. The drip was directly down, with force, around an inch from the transom wall. At that time, I could not see the direct source. Since then, I've removed the bell housing as well as more interior obstructions to improve my view. I can now see the plastic fitting that has the hose connected to it which runs up to the steering cooler at the top of the engine.
My struggle now is that from the outside, I see the inlet hose connects to right angle white plastic hose bib, and it doesnt seem to be serviceable from the outside (looks like maybe some sort of rubber grommet securing it). From the inside, I see a bolt on each side of a flange with a black plastic bib pointing up at a 45 degree angle. I have yet to determine whether the hose has failed or if the connection is just loose. I'd like to replace the plastic thru-hull piece but I'm unsure of part number. Are these somewhat universal across the alpha/bravo line or do I need to be very accurate with model/serial number? Also, which component serial number drives this answer? Outdrive, Transom, or Motor?
Also, I did have a small drip out of the shift cable at the top of the motor. It was much less volume but nonetheless, Its being replaced.
I'd appreciate any insights on the part replacements as well as general commentary on my diagnosis. I'm getting into panic mode as my week-long trip to Norris Lake in Tennessee beginning July 3 seems to be at risk. No shop would take the job under such time restriction. I'm beginning to feel overwhelmed mainly due to the necessity for some specialized tool at each step of the way.
