1998 40 hp force
1983 ercoa 21'
Looking at a pontoon with a 98 40 hp force my question is this a good motor do they have any notorious problems? This motor will be used in a small lake and performance is not a issue but dependability is.
MickLovin
Master Chief Petty Officer
Re: 1998 40 hp force
First check would be compression, there are others in this forum who own force outboards and they will give you a better idea of them.
Does it have a history of service, does it start first kick and pump plenty of water, idle smoothly, do you know how many hours are on it?, all questions you would want to know the answers to. As I say though others here will know more about the actual motor.
A 98 model is now 16 years old, so you would have to expect some ware and tear. Being on a pontoon in fresh water I would expect the motor to be in reasonably good condition, depending if they lifted the motor out of the water and regularly maintained it.
jerryjerry05
That motor has a Force powerhead and Mercury electrics and Mercury lower.
I'd check the compression and spark and the oil in the lower.
Those check out? BUY!
Usually on a pontoon they have trim/tilt make sure it cycles right.
That year it's a Mercury system.Usually no problems.
