A.Hoj
- May 24, 2006
- 39
I did some searching here and other online sites but I can't find the info I need. I am wondering if there are any other carbs that will work on my motor (middle or bottom) besides the ones that came on the motor. The numbers are WB134A-734 (854450). These carbs are hard to find and I haven't been able to find a replacement yet. My issue is with the bottom carb, I've rebuilt them all but the bottom carb keeps letting fuel leak past the inlet needle and overflows when I pump up the primer bulb. I think the needle seat is damaged or screwed up just a little and since they aren't removable I have no way to fix it. If you know of any other solutions besides finding a replacement carb please let me know.
Thanks,
Andrew
Thanks,
Andrew
