1998 evinrude 115 won't start or tilt
Status
Not open for further replies.
jberd321
Hi all. Im fairly new to boating and outboards although Im mechanically inclined. I took my boat out scalloping last weekend and got in some shallow weeds, Im trimmed up as far as i could and put it just barely in gear and proceeded to move west. When the water became deep enough, I trimmed back down and accellerated, and the rpm's wouldn't pick up. So I put in in neutral and revved it once or twice... then I smelled that it was overheating so I quickly turned the motor off. I thought something must be clogging the inlets so i tried to trim up and nothing! I got in the water and the inlets were full of grass, i cleaned them out and got back in the boat and now it wont start or try to start, the trim will not go up or down on the remote box or cowl. All other electronics work still. Just no tilt/trim or start. After taking of the cowl I notice two burned through wires by the spark plugs on either side. I think these are temp switches? I never got a warning horn or beep either. But Im sure these wire were not burnt before. Im already checking into replacint these temp switches but what else should be checked? Why wont my trim work? Does this sound like a major problem to anyone? Please help!
Daviet
Re: 1998 evinrude 115 won't start or tilt
You have lost voltage some where, are your battery cables really clean and tight? Use a test light or volt meter, start at the battery and start checking your electrical system and see where your voltage loss is.
mark1961
Ensign
Couple of simple things you need to check first up to establish where youre at.....
Battery has full charge, all connections are good.....
Engine's not seized, try turning the flywheel by hand (clockwise).....
jberd321
Thx, thats where ill start. All the other electronics work fine, but I will start at the battery, and check to make sure it didn't seize. But Its doing absolutely nothing when i turn the key, so Im hoping i just lost power. Does anyone know if theres a main fuse or fuse block some where i could check?
jberd321
@daviet, that page is exactly what i was looking for. nothing like that in the manual. I cant mess with it till this weekend. But ill let u know what i find. thx for the help.
Daviet
Hope you get your problem fixed.
jberd321
[/IMG] <pics of the burnt wires that i think are thermal switches, any info? also the motor is not locked up i was able to turn it by hand. Found no blown fuses at the motor but i have to look in gunwale compartment still.
chalmzz
Hi, I am having same issue did you ever get this resolved 2009 Evinrude 115 etec
GA_Boater
Notice the last activity date;
Closed because the OP isn't coming back just for you. Start a thread.
Status
