Xfactoreffect
- May 25, 2025
- 2
1998 Evinrude 60 HP 2 stroke on a 17ft 1991 Swan point. I went out on the water this weekend, and when I was accelerating, everything seemed fine except that I was going about half speed with the throttle fully forward. The engine sounds normal; it doesn't sound like it is bogging down. I swapped spark plugs and played with the linkage for the throttle cables on the motor side( I had a trolling motor installed, and when they ran the wiring to the center console, I noticed the throttle cables were pulled out a little more than usual, but I don't think that's part of the issue.) and nothing helped. I did a compression check, and all three cylinders are reading 90 on the dot. I had this out 2 weekends ago, and there was no issue. They also disconnected my tach, and I can't figure out what/where it is disconnected. I couldn't tell what RPMs I was getting on the water. I replaced the impeller and rebuilt the carbs a couple of months ago and have had no issues. Any advice would be helpful. Thanks in advance.
