1998 Glastron GS 225
Paul66
Will other Glastron open bow's windshield's fit ?
Glastron doesn't make the windshield anymore and a replacement for the driver side glass is close to a grand.
Re: 1998 Glastron GS 225
Ayuh,.... Probably Not.... Measurin' is 'bout the only way to figure out if it will, or won't....
DuckHunterJon
Is the frame damaged, or just broken glass. If just glass, find a good glass shop, they should be able to fix you up, but fyi - glass is getting more and more expensive!.
Paul66
No frame damage but no glass shops in the area want to touch it because of the curve on the end :/
