Well, I though I fixed all the issues on this engine. Not so anymore. It started having an intermittent issue where it begins to misfire at higher rpms. Carbs were cleaned prior to this and it runs great sometimes. It will idle fine but as soon as revs go up it misfires. It does not always do this but if I run it for more then a few minutes it will happen.
I already replaced the impeller and thermostat and no alarms go off so i doubt it is entering SLOW mode. I removed the coil and power pack. Connections on power pack were very corroded so I ordered a used one which is coming soon as I need it regardless. My question is, assuming the power pack does not fix it, will a spark tester show that there is a problem if it only occurs at high RPM?
