1998 Merc 3.0l Front Engine mounting.
alldodge
Problem is the output tube from the pup was not connected to the upper half of the drive
Nick36
Ok, so if they became separated wouldn't water still be drawn in by the pump and just leak out the front of the drive housing? The impeller didn't seem to be drawing any water in at all.
Nick36
Do you mean how flexible they are? They seem pretty flexible and there are no cracks in the rubber or anything. To me (untrained eye) it seems to be in good shape
alldodge
Don't know how much sand was on top the lower half, but it appears sand and water made it thru the pump.
On another thought, what does the engine coupler look like?
Also rotate the drive shaft and verify it does rotate the lower
Nick36
The face seal was totally gone too. Bought the kit and installed new impeller, housing, gaskets, face seal, o-rings and oil seal carrier. Going away for the weekend, but I'll report back as soon as I can! Thanks for the help.
Nick36
Oh, and the engine coupler looks good and the drive shaft does rotate the prop when I've got it engaged in fwd gear
