Captain Ken
- Oct 24, 2006
- 7
A continuation from a previous post, lost RPM's at WOT on motor, max was about 3500. Went through entire fuel system and had technician look at it and put diagnostic light on, which intially showed code 33 (knock sensor?) but that eventually cleared and all was normal. After running motor for the guy he tells me it appears to be a bad fuel situation, most likely water in fuel.
Thus far I have replaced all 3 LP fuel pumps, swapped the O2 sensor with the other motor, cleaned the VST filter and replaced all filters. Upon pulling the plugs it appeared the lower two cylinders on the stbd side of the motor had more carbon build up than the others.
I'm also seeing some gas residual in the water, coming from the exhaust I assume while idling the motor.
I switched fuel supply from port motor to stbd and vice versa, checked fuel system vacuum as well as rail pressure on problem motor, all appears OK and according to spec.
Last time I tested the motor the situation seemed to worsen with the motor not sounding right and cutting out at about 2500-3000 rpm on occasion and a vibration being felt in the throttle control as the motor died. Eventually I got the motor running again but was only able to obtain 3500-3800 rpm.
At this point I'm fairly convinced its an electronic or firing issue of some sort.
Any advice on how to further troubleshoot?
